buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
O.K. Viper guys, since it appears I'm going to be able to join your ranks for next season I have a couple questions:
-Since the skid is pretty much all Cat are the bolts etc. metric or U.S. ?
-If I wanted to keep one of my sets of Simmons skis, I assume I'd have to buy Cat mounting plates, Yes?
-Secondary clutch......will a clutch off of a RX/RS series fit on these splines? I'm kinda doubting it but I have a perfectly good Team secondary I'd like to re-use instead of just letting go to waste.
Thanks!
Thanks!
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
buddah said:O.K. Viper guys, since it appears I'm going to be able to join your ranks for next season I have a couple questions:
Thanks!
It seems like there is a variety of different sizes, most metric, and different size torx.
Yes you would need a mounting kit for the spindles. Yamadog put Simmons and said it was a pain, but he got it to work.
And I have no idea for the secondary clutch...
I believe splines are Nytro size which are different than RX/RS series.
buddah
- Apr 14, 2003
- Wetmore, MI
cannondale27 said:I believe splines are Nytro size which are different than RX/RS series.
That's kinda what Terry speculated too.........Thanks!
Grimm
April fool's right?
buddah
- Apr 14, 2003
- Wetmore, MI
Grimm said:April fool's right?
Huh?
I was asking questions I wanted answered......I never look at the freaking calendar..........
Studroes144
The viper/nytro rear clutches are the same. A buddy of mine used a nytro secondary when he was doing clutch testing. Had one setup in the stock viper secondary and one setup in a nytro secondary and just switched them out. Not sure if they are different from the rx clutches but I can say that the viper and nytro are the same
stingray719
Studroes144 said:The viper/nytro rear clutches are the same. A buddy of mine used a nytro secondary when he was doing clutch testing. Had one setup in the stock viper secondary and one setup in a nytro secondary and just switched them out. Not sure if they are different from the rx clutches but I can say that the viper and nytro are the same
Correct, but almost everything else is different splines.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Naa Jim can play the fool all year not just in APRIl
Couldn't pass it up
Very interested in these ? as I am joining the Viper heard as well. What do you call a bunch of snakes?
Yamadoo
Couldn't pass it up
Yamadoo
stingray719
yamadoo said:Naa Jim can play the fool all year not just in APRIl
Couldn't pass it up
Yamadoo
Snooki?
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
a group of snakes is called a pit, nest, or bed. According to the google anyway.
cheers!
cheers!
yamadoo
- Jun 3, 2003
Snooki --don't follow, probably just funny.stingray719 said:yamadoo said:Naa Jim can play the fool all year not just in APRIl
Couldn't pass it up
Yamadoo
Snooki?
Stingray719 thanks for all the clutch help with you and Nospro will be geting next fall I am sure.
subysti04
Unless they are rattlesnakes then they are called a rhumba.
- Apr 14, 2003
- Hessel, Michigan
yamadoo said:Snooki --don't follow, probably just funny.stingray719 said:yamadoo said:Naa Jim can play the fool all year not just in APRIl
Couldn't pass it up
Yamadoo
Snooki?
Anytime bud!
- Apr 14, 2003
- Hessel, Michigan
subysti04 said:Unless they are rattlesnakes then they are called a rhumba.
LOL
