a few nitrous questions
number1kyster
Vermont
2018 SW RTX SE
how relaible is the set up, how much does it cost to refill your bottle? And is it a button your puch or is it tied in with the throttle?
I had a Nitrous Express kit on my RX1 and it was very reliable.I used a arming switch to turn on and a button on the handle bars to trigger the nitrous flow.Worked well for me.I was filling the 2# bottle from a 10# bottle and if I remembe correctly it wasabout $35 to fill.I would still be using it but I now have a turbo.
All the nitrous sytems sold, are pretty reliable.
I have Holtzman's setups on my sleds, and can say I have used probably 100 lbs. of nitrous in the past 3 years, and absolutely no problems.........except the bottle going empty. I refill my 2.5lbs. bottles from a 10lbs. mother bottle at the hotels, or at the races. Cost for nitrous ranges $3.00 to $5.00 a lbs.
Have had the throttle switch, but like the separate left thumb, so I can let off of the switch, but still stay on the throttle when I loose traction.
