kodak
I have a 2014 viper xtx with hurricane Turbo and clutching setup at 0 and 1 on helix about 3 weeks ago did some riding in low snow conditions and sled was around 8900 max rpm and would lift the ski about 2 ft off ground in places where snow was a little deeper with ease. Last weekend in great snow conditions from 2 ft powder on ponds to 4 to 6 ft powder in back country max rpm was 8200 and ski would not lift off ground anymore than 3 inches on flat . Belt looked good but could be worn a little and has 900 km on it out . I just put a new belt on as I was leaving and without a helmet tried to check out max rpm and saw 8400 but probably could of had more but to risky without the beanie on when hit throttle from take off hit rev limiter . Not much snow to test on where I live but can a warn belt bring down rpm because I thought it would raise rpm and slip if warn. A little help and maybe some education on how belt wear affects rpms would be appreciated . I turbod the viper to do wheelies and catwalks so need help to get there . I will contact Dave from hurricane for help he has always been helpful and available but wanted to see if anyone had some insight into possible solutions and I do not feel this is a turbo issue but maybe more of a clutch or belt issue. Thanks my finger is tired now and needs some rest
