- Dec 4, 2014
- 2015 RTX LE- Hurricane Turbo
oops sorry forgot you had the 1.7" track but im sure Allen will get it figured out. I was all over the place on rpms until he fixed mine. Spring bind is a problem but not sure why you guys are dropping that low on rpms mine would go to 8900 then drop to 8200 then rise to 8400 and stay there on lakes.
Ya mine did that to when I regeared it., couldn't figure it out... So I out the stick gears back in... If you figure it out do let me know ! Are you running the stock gears tho ?
stingray719
XTX get the weight off your skis, the deeper the snow the slower you go.
http://www.ty4stroke.com/threads/interesting-skid-shock-spring-info.131147/
kodak
Sting I've been checking out that thread out for a while and over summer I am definitely getting shocks revalved and heavier spring but my biggest issue for now is a loss of rpm and I am in process of working on that . crossover sled should not come with a spring as soft as mountain sled.
Yes I have stock gears in mine and had Ulmer go through the whole machine. We did all of the clutch machining and he re clutched with his kit for the new 12#'s of boost.Ya mine did that to when I regeared it., couldn't figure it out... So I out the stick gears back in... If you figure it out do let me know ! Are you running the stock gears tho ?
