jlemieu1
- Feb 7, 2005
- Rosemount, MN
- 14 Viper LTX SE, 14 Viper LTX
I was wondering if "8ET-W8192-00-KT" would be the right part to add a 12v plug to a 08 Vector LTX.
Also would I need any additional parts to add this plug?
Thank you for your help.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
That number would be the correct part to get to add an accessory outlet to that sled. No additional parts would be needed as the sled is prewired to accept the dc outlet. You will find the factory pigtail in the wiring harness below the access panel that you will put the hole in to mount the dc outlet.
