Petterssonmotorsport
- Nov 2, 2012
Hi,
I have started to adjust my power comander map and have some questions, I have had a Ulmer map for Kn filter and exhaust system. Now we have the high lift cam ported head and bigger valves. have mounted a lambda and it is now showing 10.7 at full throttle, I want to be on 0.9, have tried to increase fuel in the graph as the program shows, from 6 to 12 but will be no noticeable difference in lambda guage.
How much does a number., From 6 to 7? or am I doing wrong?
Hope someone can help me!
/ Nicklas
/ Nicklas
Petterssonmotorsport said:Hi,
/ Nicklas
I thought there would be a direct relation as I adjusted mine but for some reason you need to make bigger jumps to see changes. I think you can change the AFR factor and that will make the change faster... from what I have seen on a PCV, I would do 5 at a time or even 10 points for bigger changes.
- Nov 2, 2012
Hello again, It's PCIII usb I use, I tested without a PC and then showed lambda 0,99-10.2 ¨
it is true that a lower lambda value requires less fuel? If this is so, it seems it will have less fuel than the original map? I think this seems a bit odd?
Petterssonmotorsport said:Hello again, It's PCIII usb I use, I tested without a PC and then showed lambda 0,99-10.2 ¨
There are certain spots in the fuel curve that it will require less fuel. I don't think it is all that odd. There are other places that require more.
- Nov 2, 2012
Okay, it's a little hard to see in just a meter while driving, but at full throttle shows the 10.2 and should be 0.90 I'll give more fuel at full throttle? Thanks for the help
Petterssonmotorsport said:Okay, it's a little hard to see in just a meter while driving, but at full throttle shows the 10.2 and should be 0.90 I'll give more fuel at full throttle? Thanks for the help![]()
Correct... the sled needs more fuel so in the map you need to have the Power Commander take fuel away to lean out the AFR to raise the number. I know on a stock Apex, you can smell all the wasted fuel when you ride behind them.
- 6K
