Silverado43
- Dec 7, 2018
- NY
- 14 Arctic cat xf 7000
Who has successfully ran airbox mod and can without a controller or map. If so how many miles have you been and what are you riding. Thanks. I already know the safe answer is to get a controller. But I was hoping to run the airbox mod with my mbrp can without havin to get a controller.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Welcome to the forum. Many questions have been asked and answered, search is your friend.
https://ty4stroke.com/threads/air-intake.154089/
Silverado43
- Dec 7, 2018
- NY
I have done alot of searching and even talked to cannondale. But didnt find anything on who was actually running both without a controller.
Silverado43
- Dec 7, 2018
- NY
Thanks sometimes just need to be pointed in the right directionWelcome to the forum. Many questions have been asked and answered, search is your friend.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I ran a sandale can and ulmers 3 k&n individual filter setup without a fuel controller for 3000k miles with zero issues, just needed to clutch for it, then I ran a slp header with evo stage 4 flash but eventually went to turbo, should have skipped everything and went straight to turbo, live and learn I guess
rbell14
I've got Ulmer's air box mod and can without any fuel controller. Logged over 4,000 miles with it with zero issues.
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
airbox mod evo stage 4 flash mbrp trail can ulmer header and clutch kit without controller 5000 miles with no issues
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Evo flash is a fixed non adjustable fuel controller.airbox mod evo stage 4 flash mbrp trail can ulmer header and clutch kit without controller 5000 miles with no issues
I gave the safe answer. Get a tune. If you have to ask you are worried and should be safe. $ isnt everything and Ulmer or Evo both have great tunes which ever you choose to do. Plug and play for either.
Another point is if you feel you need to mod it will not end its addicting. Buy for the future.
Studroes144
- Oct 30, 2013
We ran a modded air box on a 2014 xf7000..started awesome, ran awesome, noticeable performance gain..added a can and it started terrible! Had a couple kick backs right away, made a few passes with it and pulled the can right back off. This was at roughly 700 feet elevation. Would’ve liked to have put a pc5 on it because it definitely made power, just wasn’t safe on that specific machine given all the starter issues.
Silverado43
- Dec 7, 2018
- NY
Good points by cannondale. I already have the mbrp trail can and so far no issues. Guess I'll have to look into a tune or controller in the meantime.
