Airbox
mud99
Truckee, CA
Can someone help me understand what all the connectors to the airbox are?
Front small hose on bottom: water drain line
Big hose running through airbox and down: oil puking apparatus
Big hose on back running to the carbs:?
Sensor on the side: ?
Mark
One is the drain incase water comes in
the sensor should be your IAT (air temp) sensor
One should be the equivialnt to a PCV (excess crankcase pressure)
And Im not sure what the last one is without looking at it to see the routing..
The last one goes out the back towards the side of the butterfly valves on the air temp sensor side. It's the same diameter as the PCV.
Mark
