Alignment Specs.
SSX600
Richland Center WI
2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
I just installed new oilite bushing from Ulmer's racing in the front a-arms and ski spindle bushings in my Nytro XTX and now I can see that the toe in is way out of wack toed out bad. Can someone give me the toe in spec for this sled. Can't believe that it is this far out of spec after only installing new bushings but I guess they is play in the factory bushings when they are new.
1/8 to a 1/4 inch toe out.use a bungy strap to hold the skis tight,put it from ski loop handle to the other,then adjust,toe out is what you want
the the nytro manual is in the nytro general talk FAQ section that has all of the specs in it. I downloaded it and I use it almost everyday
