Dewbo
- Mar 9, 2018
- Michigan
- 2018 Yamaha Sidewinder
ok, saw a post on anti seizing exhaust bolts...can't find it now, have the plastic off the sled....are we talking about the torx bolts on the muffler exhaust flange? The ones holding the muffler on the turbo? Also I see 2 that won't accept my 50mm torx....what's the preferred wrench for those? Thanks
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I bought a Torx bit and basically ground off the back until it fit. Then turned it with a 1/4" wrench. Make sense
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Dewbo
- Mar 9, 2018
- Michigan
Yes makes sense...so, the anti sieze post I saw, wasn't the exhaust bolts to the head? Those look like they would be tuff to get to.I bought a Torx bit and basically ground off the back until it fit. Then turned it with a 1/4" wrench. Make sense
Doc Harley
- Oct 17, 2016
- Here & there
Just the six Torx bolts on exhaust flange. I used nickel grade 2600° anti seize
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Only could find Copper anti seize locally 1800-2000°. Hope it's enough, I think anything is better than nothing. I replaced torx head bolts with standard head bolts so I didn't have to use that contraption in the pic again....lol
burlyviper
- Apr 30, 2012
- Ottawa Lake MI
- 2018 Sidewinder LTX LE, blue
2011 Apex 128, Ulmer Airbox and clutch kit, PCV, HID
1980 Exciter 300
I think this is where you saw it
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-let-the-mods-begin.149801/
#38-40 on his list
#38-40 on his list
POWERHAULIC
Curved jaw vice grip works fine for removal also........lol
Replace with hex bolts, or a different exhaust that does not block them.
