American Hauler Trailer Light Question
BOUNTYHUNTER
Staff member
Moderator
WINTERPEG / MANITOBA / CANADA
OK…Bulb burnt out on the trailer; an American Hauler and was thinking about putting LED’s into it instead. Most trailers I’ve seen you just pull out the lens cover from the rubber boot to get to the bulb and harness, well unless there is a special trick to this one…IT ISN’T MOVING!!!
lens
if its cold, that rubber boot will be stiff. youll have to put a screwdriver between lens and boot and CAREFULLY pry lens assembly out. YOu may have to lubricate the edges of the lens assembly to get it back in. the rubber tends to harden, even in warmer weather.
