hlmrx1
Did a quick search and couldn't find the info that I'm looking for (I'm bad with searches). Has anyone loaded more than one washer in the mid and tip of heel clickers? Is there enough clearance for this? I know that the instructions state, not more than 2 washers in the heel, and I've got that, plus 1 washer in the mid and tip, need more weight as it's bouncing off the rev limiter. Running White HC spring. Almost there, and I think another washer in each location might do it.
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
I have run up to a 1/2" bolt with 2 washers and a nut on other side makeing 9grams on mine but had to file a little off head to clear spider.
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
hlmrx1
I tried a second washer and there basically no clearance and will more than likely hang up. I called the manufacturer today and they told me they use standard bolts that can be sourced at a hardware store and told be to pick up a Hex 1/2" long bolt which should give me an extra gram on each weight. I went to the local automotive hardware store today and picked up 3 - 1/2" bolts that weigh 5gr. each, so I should be able to go with those without a washer to give them an extra gram. I have not had time to try it yet and have to make sure the heads clear.I have run up to a 1/2" bolt with 2 washers and a nut on other side makeing 9grams on mine but had to file a little off head to clear spider.
hlmrx1
These are 50-20 Heal Clickers and after reading it over carefully, it states, no more than 2 washers in the shoulder and no more than 1 washer in the mid and tip for these weights.
http://heelclickerclutching.com/tech-info/pdf/HC-2-Speed-Yam.pdf
