redman
Each time out my antifreeze levels drop down to the bottom of the resevoir. The oil is dark not milky and exhaust is not white. Can not see any antifreeze on the snow or any leaks. I put on a coolant shut off this year. Does anybody else with one on have any problems with antifreeze disappearing? I run with it on for the first 5 or 10 minutes then shut it of for the day. I noticed one day when I squeezed the main line after riding that AF ran out of the overflow hose. Coulf it be heating up enough and ruuning out the overflow? Any ideas? Thanks for any input.
Past experience 03/04/05--When cold the anifreeze level is at the bottom of the tank. When hot it is at about the cold line. Have added a couple of times & they all seemed to return to those limits.
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
Does the temp light ever come on?
redman
It came on going up the trail once for a few seconds, just pull over and kick a little snow on the boards and it goes off. It does not come on once we hit the hills. Runs good as long as the carb heater is off. If it is left on the sled bogs and is hard staring.
