Ricketts
- Feb 29, 2008
- 2007 PhazerFX
So get this, our local dealer no longer stocks 0W30 for our sleds...the only place in town now that sells 0W30 is Walmart of all places (actually one other place but its hit and miss). Walmart has Super Tech (I'm assuming a house brand) and Castrol I believe.
Manual says to not use "Energy Conserving II" or higher, or a higher grade than CD
Both of these are listed as CF and just "Energy Conserving"
What are people running in their sleds? I questioned the salesman and he said no one was buying Yamalube so he stopped bringing it in, and the above oils should work fine.
One other store has 0W20 on sale (never heard of 0W20 before), but would this damage the Phazer?
Thanks for your help,
Rick
Rick
marpolsdofer
My dealer gave me yamalube 0w40.
Mobile 1 0w-30 From Wal-Mart, it seems like the cheepest place to get it.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
Mobil 1 is not available at our Walmart. Is it Energy Conserving?
Just wondering how big of an issue it is...Energy Conserving or not?
WTF That not right.
wienerwater
- Mar 1, 2007
- Northern British Columbia, Canada
Why not use 0-40 Amsoil Powersports oil? It works fine and a great product.
QUADSCRIB
0-w20 is mainly for Honda cars and a few others.
marpolsdofer said:My dealer gave me yamalube 0w40.
The Yamalube 0w-40 is the fully synthetic. The Yamalube 0w-30 is the semi-synthetic. I use the 0w-30.
You sure about that? I've never heard of a Honda (or any car for that matter) taking 0w-20 fromt he factory. The 4 Honda cars that I have owned have taken 5w-30 like most other cars. Our Ford work vans take 5w-20, though.
marpolsdofer
never mind that what have 0w30 semi, amsoils 0w30 is full.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
wienerwater said:Why not use 0-40 Amsoil Powersports oil? It works fine and a great product.
As in post #1...nobody sells anything in my crappy little town
Back to the energy conserving question, what are the concerns with using it? The dealer says its OK, but I would like to hear what the guru's say.
Thanks,
Rick
I use the Amsoil 0-40 in all my toys.Zinc and Phosphorus content is why.They were removed from many newer oils because they will ruin catalytic convertors and sensors.If you research the subject they also protect cams.Oils with a SJ rating in them normally have alot of these.Now first two oil changes I ran Yamalube with no issues at all.I think if everything is right in your motor there is probably no reason to need the extra protection the Zinc and Phosphorus in oil provides.However if say your camshaft isnt quite up to spec as far as hardness or for some reason oil is slow to get up to topend it is just a little insurance.Can I prove it?No.But Cannondales had some really bad cams and I never had a issue while many did.I always ran the Amsoil.
Ricketts
- Feb 29, 2008
- 2007 PhazerFX
Thanks for the info.
Rick
Rick
Phazed said:The Yamalube 0w-40 is the fully synthetic. The Yamalube 0w-30 is the semi-synthetic. I use the 0w-30.
service manuel of phazer ,nytro and apex say to use 0w30
can affect something to use yamalube 0w40 full?
It is worth the price? if I run it's hard
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
I run Mobil 1 0W40 full synthetic available at Canadian Tire and Parts Source. Checked and it has a bit higher Zinc content than their 0W30. It is not Energy Conserving so it's all good.
What you have to remember is that the numbering is:
0 = the viscosity cold (0F)
W = winter rated
40 = the viscosity when hot (210F)
So basically, by running 0W40 instead of the recommended 0W30, the oil is a little thicker when it's hot, which provides a little more protection but may affect HP at high RPM. Cold weather starting is not affected.
W = winter rated
erosled
Energy Conserving will affect the starter clutch. In simple terms, don't use oil that states energy conserving. 0w30 is standard rate, but being the temps are going up 5w30 would be fine.
- 13K
