Another Tri-Hub Flush
Nivled
Kenosha County, WI
2016 SRViper L-TX-DX ((Stingray Airbox Mod, MBRP Trail Can, Thunder Products Big Venom Clutch Kit, Stingray Front Skid Shock Spring, 4 Wheel Kit, BOP Belt Adjuster, Custom Track Adjustment Guides))
2014 RS Vector LTX
Bought the JT 4th Wheel Kit and was going to install it today. Discovered that the OEM wheel guide was cracked. Glad I caught this before the season started. The JT kit doesn’t come with one. Is there an aftermarket part for this or does every just re-purchase the Yamaha 8JP-G7534-00-00 part?
$35 from grip and rip racing. Billet aluminum.
Already bought that kit in August. I was finally getting around to installing it when I found the cracked guide. JT’s kit does not come with replacement guides.
Checked those adjusters out earlier today and found them. Just checked and no longer available.
Turbo dynamics sells the grip n rip adjusters. I just bought a set as mine were cracked.
Grip n racing ajuster. I feel this piece is required to make this kit more reliable
That whole assemble was removed from both new sleds from the get go for me. Chalk this one up to another reassuring story that was a good move. Can't say enough good things about the larson kit so far!
Happened to take a second look at the parts I removed and looks like BOTH sides were damaged. Missed the hairline fracture on the other part. Only had 1,500 ish miles on these. Going to junk the OEM replacement parts I bought and buy aftermarket ones.
