mud99
So i'm thinking of going to a power claw track, and I hear that I should run anti-stab wheels.
Can someone recommend an inexpensive anti-stab kit? All the kits are like $100 and include 4 wheels, do I need 4 wheels or is 2 enough.
I still have the 2 inner wheels from the factory suspension, maybe there's a cheap cross bar I could buy to mount these up front?
Mark
Mark
Get the Wahl kit, and run the inner wheels only, the wheels needed are smaller than the 2 factory wheels you currently have and there is not a lot of room at the tips to go big. Wahl uses a 1/2 od shaft if you want to source the parts seperately.
TurboMatt
dumb question... but how exactly does an antistab kti work?
It is a shaft and wheels that mounts where the rivets are on your rail tips that prevents the rails from going thru your track at the windows as the tip point of the skid is now 12" wide instead of the 1-1/2" tips by themselves
I've been shopping for an anti stab kit as well. If you're getting one, this place is running a 15% off sale until Jan. 8th. They have the Wahl kits for $80.71 instead of $95.
http://shop.hyperformanceparts.com/productdetail.htm?productId=9996459&ez=anti stab
- 80K
