no-fear-875
- Feb 17, 2008
- Kalkaska Michigan
- 2007 yamaha apex rtx/2005 rx1
- Kalkaska Michigan
I thought it was coming from the heat exchanger under my foots on BOTH sides, but now looking at it closer, the stream is coming from down the inside of the tunnel, it's not pouring out, but it is leaving a puddle on the floor on each side of the sled, i haven't taken off the seat to look yet, i have been sick, but is there something under there that i might be concerned about? Anyone else know any common problems about this? 17k Miles on it now.
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Is the sled studded?
You won't find anything under the seat that can leak coolant. My guess the your running board exchangers are leaking.
This happened to me a few years ago. I had a/f puddles on each side of the sled in the am. At first it looked like from the inside of the tunnel. Traced it down to the running board exchangers.
Installed some good used ones and added tunnel supports. So far so good.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Mine cracked 3 times by the rear ski mount. Think tunnel supports like steiner said.
Whats a rear ski mount??Mine cracked 3 times by the rear ski mount. Think tunnel supports like steiner said.
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
Skid. My fingers have a tough time keeping up to my brain, not that it is all that quick either.
YammyRX1
- Jan 26, 2009
- Milton, on
- 2003 Yamaha RX-1
My guess would be side heat exchangers (been there) but both sides at once? If it is coming down the tunnel from above the exchangers then I think you have to look at the cooler at the front of the tunnel.
no-fear-875
- Feb 17, 2008
- Kalkaska Michigan
- Kalkaska Michigan
Well i feel like an *Donkey, lol. I took the sled all apart, did not see any leaking, no where. took the seat off and the bottom of it was wet, I was like wtf, so i just happen to look in the back glove compartment, and there was an empty pepsi bottle with about 1/4 of antifreeze left in it, squeezed the bottle and the rest came out, im about 99% sure that's what it is, taken for a test ride today.
Thanks everyone for all the help, and get a good laugh from me, lol.
CCCT
- Jan 9, 2017
- Barrie/Sudbury/Muskoka
- 2007 Apex
2009 PhazerGT
Awesome end result. Much better than any alternatives.
Sent from my SM-G935W8 using Tapatalk
Good one
that would do it.
steveg_nh
- Jul 23, 2017
- Southern NH
- 2007 Attak
I know this is from last winter, but I'm curious if that really was your problem? If so, lucky you, except that you did take the sled apart.
