MUSTANG1
- Oct 6, 2005
- Canton, MI
- 2016 VIPER L-TX-LE BLUE
I have 700 miles on an 07 Apex. I've started the sled once a month and ran for about 15 minutes. This past weekend, the sled would start up for about 2 seconds and shut off. Tried this 3x and quit. Any ideas?? Battery tender jr. has been used off and on to keep a charge. Would a weak battery do this, I thought once the sled fired up it would keep running. Never had this issue with my 03 carbed after 8,000 miles. Any insight would be appreciated. I took the headlight unit off so I couldn't see if there were any codes firing.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Put in new spark plugs and I bet it fires right up.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
I don't think it will run without the instrument cluster hooked up.
- Apr 17, 2003
- Menno, SD
- Menno, SD
It will run and idle fine without the instrument cluster.
attakred06
attakred06
