sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Would it work if you put your brake rotor in a vise and then put the axle through it. If you're worried about the surface you could always clamp it between a few pieces of wood.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Could you not just put a pipe wrench on the drive shaft and have someone hold it ?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Pipe wrench is how to hold it. No need to have someone hold it. You can do it solo.Could you not just put a pipe wrench on the drive shaft and have someone hold it ?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
No chance of denting or leaving dimples?
Ms
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
The pipe wrench will leave a couple marks, but no dents that I could notice.No chance of denting or leaving dimples?
Ms
Fast
- Sep 25, 2018
Travis said he was going to make the new ones longer since he never made it any longer after machining the flat spots that were suppose to be inside the shaft, i made 1/8" custom wrench to tighten it up, problem is if flat spots are left out it could lock the brake rotor as well as the bearing giving it pulses on the brake leverWell thats news to me.. sounds like he needs to make them longer then.
