ANY MOUNTAIN SKI USERS ON ATTAKS???
stormchaser said:
yrunderattak said:
you have to use the bushings from your stock skies. they just pop out.
Thanks, don't look like I will need the skis too soon anyway-stilll have longer bolts on back order.
Like was said, you have to use the bushings in the stock skis for the carbide stud holes. I have received the collars and bushings, but the bolts are on backorder till mid January. I'm going to get them at Lowes or a hardware store today. The size is M10 x 160mm long. Just get some nylon lock nuts with them.
If you can drill a hole after the nut thru the bolt to put a cotter pin in i had a nut come lose once and it was a nylock nut.
Any more trail running with these skis at high speeds and cornering?
I know the flotation would be lots better than stock Attak!
I'm wanting more bite in the corners too!!!
NO PUSH!!!
BR
Got them on my attak but never ride trails so don't know how they will work on trails.Love the floatation and no more snow kicking in your face with the m/skis.
400 Klm on mine with Mtn skis and the stock carbide. Great
for flotation and steering but found them darting from 40- 80
klm on packed but once you pin the throttle its ok so maybe
a set of woody doubles or shimming would fix this time will tell.... ;)!
TB
