Any tips for polishing the tunnel?
If you are going to polish use the purple polish from www.californiacustom.com It very easy to use & has a sealer in it wich makes bring the luster back no problem. After using it for three years I can do a tunnel in 10-15 min or 1-2 beers. Most of the time you find the Purple Polish @ truck stops..... Most truckers do their fuel tanks & wheels with it. Use the green acid wash if whatever you are polishing is nasty...... Makes it much faster. Possably could use a Mothers Powerball on the running boards to speed things up even more....
