Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Here’s pic s knapp thanks for info it’s worth a tryI wouldn't be buying generic relays from Amazon or anyplace else. I would buy OEM relays with that Polaris part number. That means the Polaris dealer as far as I'm concerned. After all, thats the only place to get the OEM number. They have to be a Polaris dealer with that PN.
Pan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Pan
All the credit goes to Snoseeker and I suspect journeyman had a hand in it as well! Thank those guys, they must be off riding somewhere that they haven't commented yet. I'm just reporting what Snoseeker told me about the solid states from Polaris.
Lets hope it helps people from further frustration in cold weather startups.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Just what I needed. My FrankenWinder didn’t have any Polaris parts on it yet.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Also curious if it’s actually solid state or just sealed better? Anyone take it apart?Snoseeker told me the Polaris one is solid state and for the fuel pump.
KnappAttack
- Feb 19, 2004
- Welch MN
I havent, they are too expensive to take apart. LOL!
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Well thanks to snoseeker and journeyman and you as well for sharing infoAll the credit goes to Snoseeker and I suspect journeyman had a hand in it as well! Thank those guys, they must be off riding somewhere that they haven't commented yet. I'm just reporting what Snoseeker told me about the solid states from Polaris.
Thanks Pan
stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
I agree, Thanks everything one. C'mon SNOW!Well thanks to snoseeker and journeyman and you as well for sharing info
Thanks Pan
KnappAttack
- Feb 19, 2004
- Welch MN
Just spoke with Snoseeker and he found out they are not solid state, but they are sealed to prevent moisture from entering and freezing up. So theoretically they should be better than the OEM one in the sidewinder now.
Lets hope they do the trick anyway. We gotta try something different anyway, cause the OEM one is not up to par.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Is this more of an issue with guys who keep sleds inside? Mine is in UNheated shop all winter, and I havent had the issue yet, My apex never did either.
Dan
Dan
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Always in a heated garage. Never a problem in 13yrs with the Apex. Never had a problem with the Winder. Hope I didn’t just jinx myself!Is this more of an issue with guys who keep sleds inside? Mine is in UNheated shop all winter, and I havent had the issue yet, My apex never did either.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I often assumed the heated garage, then cold air were the culprit in moisture creation, leading to freezing.Always in a heated garage. Never a problem in 13yrs with the Apex. Never had a problem with the Winder. Hope I didn’t just jinx myself!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Remember when below freezing outside humidity is usually low inside.I often assumed the heated garage, then cold air were the culprit in moisture creation, leading to freezing.
KnappAttack
- Feb 19, 2004
- Welch MN
Dan
Dan, It's more of an issue for leaving the sled sit out overnight and starting the next very cold morning when on a trip and sled sits outside. Like 20 below or colder.
When it happens that it doesn't start, the hoods got to come off and relays need to go in the pocket or inside to warm them up. Not good when its 25 or 30 below out.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
True.....but also when you move a hot item into cold air, it usually makes moisture. Like when you bring anything warm outside and see steam.Remember when below freezing outside humidity is usually low inside.
I just hope I don't have this happen, I never did before but now I may have jynxed myself..lol
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I hear ya Mike....I worried abit this in Qc last March, it was coldest temps Id rode in pretty much. About 4 sleds at hotel did not start, I watched them all work on their doos, and buds POO.....went out, fired my winder right up, albeit had to hold the throttle just a tad as engine cranked VERY slowly. However the pump ran fine at key on. So she fired and I let her warm fully idling.Dan, It's more of an issue for leaving the sled sit out overnight and starting the next very cold morning when on a trip and sled sits outside. Like 20 below or colder.
I do see temps inside my Un-attached shop up north of 20 below at times, been lucky I guess.
Dan
