Anybody have a pic of 144 studs with double backes
Re: NEXT QUESTION
twomorestrokes said:
MightyRTX said:
B2SO said:
IM having a hard time deceiding on studs or a 1.5 track on my gt , are you guys running studs hitting the tunnel at high speeds or on the brakes hard ??? i NEED more traction for coming out of corners , but hate to spend $300 on steel thats going to rip up my tunnel ...any input ???
Stick with 1,325's and you'll be all set. Studs will help you coming out of a corner better than a 1.5 inch track on our Michigan trails.
What he said! ;)! No stud contact anywhere in my tunnel with 1.325's.
i have woody's 1.18's and i am scratching my exhaust pipe-and i do have tunnel protectors...and track is tight cuz i cant stand ratcheting
Yamahammer485 said:
I had to do it again, id use red loctite along with the lock washers, so that they stand a higher chance of not coming loose again.
That's a whole 'nuther story whether or not to use LocTite with the tall nuts. (see "other tech" section) Woody's used to say to use it, now they stress not to.
