1liter
I was rideing and the gauges started blinking on and off and tach was going up and down sled ran great when this was going on but when I got home I shut the sled off and it was dead. It will start with a jump from my charger but when I rev it up the headlite dimes down even with the charger still hooked up to it. I am thinking batt is shot. I will take it out and get it tested on Monday. what do you guys think? thanks to all for any help.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
You have to test the battery and the charging system!
Put the battery on a charger and bring it up to full charge and then load test it!
If the battery is good then you should test the charging system with a Multi Meter to see if it is charging properly.
It just might need a new battery, I've seen this same thing happen to a friend on his 05 Rage.
1liter
how do I test the chargeing system? Just fire it up and unhook the batt and see if it putting out 12V at the batt leads or?
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
1liter email me and I will email you the pdf manual. bkrpaul@aol.com put rx manual in subject line. It has all of the how to and specs in it.
Bob Miller
- Apr 19, 2003
- New Milford CT
1liter said:how do I test the chargeing system? Just fire it up and unhook the batt and see if it putting out 12V at the batt leads or?
With a "Multi Meter"! You can buy one at the local Auto Parts store.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
ALso check the wiring at the front of the hood to make sure they are not wearing through. Sounds like a bad batt or intermittant short.
yamahamaniac
- Jun 2, 2009
- Jackson's Arm, Newfoundland, Canada
Yeah I agree with kinger, could be one of those pesky nose cone chaffs.
1liter
Batt tested good I need to take a good look at the wiring for bad spots and then test Stator output with a Meter I do have one but what Color wires am I looking for? and what should I have for output Volts on them? I sent you a email maxdlx thanks for your help guys.
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
check them all I had a problem like yours but I was blowing the fuse. My problem was under the seat plug was resting on the heat sheild for the tail light.
Bob Miller
- Apr 19, 2003
- New Milford CT
1liter said:Batt tested good I need to take a good look at the wiring for bad spots and then test Stator output with a Meter I do have one but what Color wires am I looking for? and what should I have for output Volts on them? I sent you a email maxdlx thanks for your help guys.
Hook your meter up to the external connectors to your Battery which are located near your oil tank. Red to Red, and Black to Black. Here are the numbers that I get on my 2004 Warrior:
Voltage at idle and at higher revs remains constant about 14.40 volts DC
