viperxtxx
The deflector works good. No bogging anymore. Not sure why other sleds that dont have them and have no problems. Maybe the 2 strokes have more exh pressure so its not that big of a deal
swampcat
I cut a piece of thin stainless to resemble a large washer, the I.D. just snug enough to go over exhaust tip, O.D. is the diameter of the outlet in belly pan, minus the rubber seal. Started the washer onto pipe, then applied generous amount of ultra black silicone between washer and muffler body, then installed while silicone is wet. It self sets into position when the muffler is in its final position. Fully tested in da U.P. this past weekend in some over da hood snow. NO bogging, SwampCat approved.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
- Nov 29, 2009
- sabattus, maine
Other sleds do it too, look up the "infamous powder bog" thread on the smoking side. Pages upon pages of discussion came down to a simple exhaust deflectorThe deflector works good. No bogging anymore. Not sure why other sleds that dont have them and have no problems. Maybe the 2 strokes have more exh pressure so its not that big of a deal
stingray719
Yep! The real issue as you found was the exhaust coming back up into the compartment. Like you did is the best, or the deflector will help too.
stingray719
Yep deflector will do it as it gets the exhaust out. Sealing the exhaust exit will also solve this issue as it is not the exhaust being stopped but rather the exhaust goes into the engine compartment and you suck exhaust into the air box.
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
All I know is I had the stock exhaust on last year and riding in powder it would bog like crazy.
This year with the max flow/Sandale exhaust it has never bogged even in the deepest powder. That testing for the last 3 days in very deep powder....never once bogged!!
Last year I would avoid turning to the right if possible in heavy powder as it would bog badly and sometime leave you in my a bad spot. This year with the maxflow it's perfect.
The best fix may be to ditch the stock restrictive can and go with some sort of aftermarket exhaust.
stingray719
Then the sandale must be like my EVO can and have a tight seal where the exhaust goes through the bottom. Makes sense.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
X2 on Sandale. Never experience bogging and I carve on the right side often.Then the sandale must be like my EVO can and have a tight seal where the exhaust goes through the bottom. Makes sense.
