WINDER1987
My father and I both have LTX Le and in order for it to go straight you have to have the handlebars turned slightly? Anyone else have this problem I drove a buddies thundercat yesterday that doesn't have the problem and he noticed it as soon as he rode mine as well
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Mine seems fine I remember reading about a few that had the bars not centred.My father and I both have LTX Le and in order for it to go straight you have to have the handlebars turned slightly? Anyone else have this problem I drove a buddies thundercat yesterday that doesn't have the problem and he noticed it as soon as he rode mine as well
Sent from my SM-G920W8 using Tapatalk
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
ALOT of us did! I always check ski alignment anyways, so i adjusted it then...
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
My BTX is like this and I was thinking maybe I did something to it
Sent from my XT1650 using Tapatalk
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
mine has the steering slightly off...throttle side slightly towards my body (brake side high). I checked my ski alignment and it is perfect, so I have not corrected the steering misalignment yet.
WINDER1987
Any suggestions on what to do and where to start with this?? Thanks
AXR
- May 5, 2007
- Central NY
Exactly. I had a post about this a while back. You need to do a ski alignment. Either open up the rubber boots and loosen the jam nuts on the inside of the tie rod or do it the cheating way and remove the tie rod bolt from the spindle and adjust from just the one end. If you do that make sure you spin the rod some and not just the end bolt, else you may run into issues if you ever decide to adjust them the correct way.
saskattakman
take it back to the dealer that's what you paid for the pdi for..or you can loosen all 4 nuts and turn tie rods equal turns say the left side up and forward with wrench do the same to right side..usually 1 turn will bring back straight
AXR
- May 5, 2007
- Central NY
That's what I did. They adjusted while I waited. My Dad's, Mine, and the one on the floor were all the same. Never assume things come correct from Cat. Should the dealers catch this? Yes. Do allot of them look at bar alignment? I'm gonna say no. Most probably check the ski toe out and never think to check if the bars are straight. To be honest I don't see why they should have to. Good manufacturing should have a jig or something to establish proper alignment of all components prior to them leaving the factory. Just sayin'....
WINDER1987
My dealer is basically worthless if I brought it to him it would sit for 3 weeks before they looked at it probbaly but they have the best prices and only dealer in the area. So I want to take the pop cap pins out and remove the rubber boots and loosen everything up and then make changes from there? How do I assure they are straight just eyeball it to the best I can?
AXR
- May 5, 2007
- Central NY
Yep eyeball it. I saw a pic someplace where a guy put a ratchet strap on each end of the handle bars and hooked it to the running boards to keep them straight. To get to those inside nuts you have to turn the bars in the opposite direction all the way and then you can sneak a wrench in the opposite side the skis are turned to. Or a wrench with a swivel head is much easier. If you have the pdi check list booklet that should have come w/your sled it tells you how to align them in there.
Moodeyblue
- Sep 16, 2003
- Alberta
- Sidewinder SE
on some of my other sleds, I used a straight edge against the track and aligned 1 ski to the track. I then measured from the handle bar tips to the back of corners of the tunnel, using this as a reference point. I then adjusted the skis so it was aligned.
If memory serves me right there is a turnbuckle between the post and the Steering frog which tierods are attached to. There is also a hole in the frog and the frame. If you stick a rod or Drill bit in that hole the skis will be straight and then you just adjust the turnbuckle to get the bars straight. No need to adjust the ski alignment as long as that is correct. Doing it this way also ensures that both tierods have same amount of thread in them in them. Look in the boots at the mechanism before you go adjusting the tierods.
ritchie
- Nov 3, 2014
- Seven Sisters Falls, Mb
- 2017 Sidewinder Ltx Le
My Handlebars are off the same as yours.
Looks like they deleted the turnbuckle in Sidewinders. So you are in fact left with no choice but to adjust tierods to get you bars straight. Shame they did that.
