RobWarrior
Looking for good/bad reviews on Hygear Revalve rear Pro-active shock?
TrailxRider
Im curious also. Ill have to send mine out this summer for next season. Mine are shot and hoping to make it this season.
RobWarrior
I'll let you know...I just traded a guy on here a set of Fox Floats for a Hygear re-valved rear shock. I had a local shop change the stack around on mine and it helped for bottoming but man is it stiff in the stutters.
TrailxRider
Im having the same problem. Normal trail bumbs feel like im hitting a speed bump with a car. It jars me and bigger bumbs i bottom out. Debating if a revalve will help or if its worth looking into a different rear suspention. Im planning on keeping the sled until it dies so trying to get it more comfortable with the bumps.
RobWarrior
I had a dealer around here play with the valve stack and it helped but they didn't have all the parts for a valve stack like the one on the apex forum...did you read that thread? it's a good read check it out...I got the shock from the guy on here and it needs to be serviced it had no charge in it so I haven't had a chance to try it. I decided to send that shock to Hygear today since it won't cause any down time to do so. I'll keep you posted.
