JDMCRX
Wanted to see a pic of the lower side or any pics of the yami acceries front skis.
josh
josh
I changed mine to the mountain ski.
Unlike my Cat ski, the bottom profile is the same as the stock ski on Yamaha. It just has a wider lip on the sides. It does not "widen" your ski stance.
JDMCRX
Im just looking for something in the deep snow that helps out. I just do not want it to handle worse in the trails
I looked at the bottom of the ski's while off and could not see any difference in the contact area on hard pack.
If you get them from the dealer , Make sure you get ALL the parts. ( took me 4 trips !@#@$$%^%)
You need 2 longer bolts, 4 spacers, and 2 longer bushings that go in the mount.
JDMCRX
These are the yami mountain saddless ski bottoms. How are they in the powder??
JDMCRX
Yes, those are what I have.
Just put them on. I have to travel for snow.
JDMCRX
Coo let me know how they far out
Yooper_Bob
I put a set on my '05 Warrior, and they ROCK!!!!!!!
The install was very easy (and I am mechanically declined).
The flotation in the deep powder (I live and ride in 'da UP) is excellent. We have had a couple of good snows and the difference is incredible.
The front stays on top of the powder instead of diving like it did with the narrow stock skiis.
Now I wanting to extend to 144" so the back will float like the front......
Yooper_Bob
JDMCRX
Im just worried that in the groomed trails they will not do good. How are they on hard packed?
Yooper_Bob
I did not notice any difference on hardpack. Ski uses the same carbides as the stockers.
If you look at the profile/cross-section, the keel is exactly the same...the only difference is the width.
The mountain skiis are lighter...gets rid of the big metal saddle.
If you are looking for more flotation, try them and you won't be disappointed.
