stealth800
I know this was a huge issue on the 05 RX1 but I thought they updated it. What is the proper fix if this happens on an Apex? Is there another update? Thanks.
LJ 452
Mine broke... but I should state for the record that it happend when I pulled my shock out and forgot to remove the cable first.
Anyway I think it costs around $9.00. The price isn't bad but obviously the labor or time to change it is not fun. I would just make sure that you have it routed correctly and fully locked in position at the boot area. I check mine before each ride just to make sure it hasn't moved or shifted out of the holder. Other than that I am not aware of any update to the cable. I would say that it seems to hold up well considering it's location. As I said the only issue I had was self induced.
stoutner
Mine broke too. I replaced it. I think I got the part covered under warranty.
chaserdog
broke mine too taking the suspension out to change the track but dealer covered it under warranty for me.
dblacks
mine broke on the 06 the 1st ride this year, they covered it under warranty
rxmaninblack
I went thru 3 of those cables on the RX1. 2 after the the update was installed. That is one of the reasons I went to the 07 RTX. No cables or wires.
BA APEX
mine broke last yr. tightened it too much when i reinstalled the shock.
