anyone know anything about error codes and diagnostics
code
Real mystery it's not even on the code chart!!
idol speed controll valve is stuck open. i did the diagnostic test and it seems to be fine. sled does not run any different. do u know how to reset the code
Hold the two buttons on the left side of the gauge down together and turn the key to the on positions while continuing to hold the two buttons for eight seconds. Once the 8 seconds is up you will see a DIAG screen. Now you can release those two buttons and press them down again together for a coupke seconds. This will bring you to another screen with a number one and usually a 16 at the bottom. Press the bottom button on the left side of the gauge until you get to a large 62. This screen at the bottom tells you how many codes you have stored or showing. Press down again and go to 61 where it will tell you which codes they are. Now press the thumbwarmer down and it will erase your codes. Turn key off now and start sled to see if codes are released.
well the isc valve is deffinately stuck wide open. the sled idles at 2500 rpm. any one know what i need to do to correct this
