SKIP
I noticed a few posts describing broken front pivot arms on the mono suspension, so I checked mine and found no cracks. But I am worried this will eventually happen.
Has anyone modified there older mono?
I think I am going to copy the 08 front arm which has gussets and add to my 07.
Any suggestions?
Any suggestions?
AttakDog
Do a search and you can see the mod pics of mine and others
footer200
- Nov 28, 2007
- Bowmanville Ontario
- 2015 Viper XTX MPI Turbo
Look in the Suspension Forum there is alot of great pics of modified pivot arms.
apltx08
SKIP said:I noticed a few posts describing broken front pivot arms on the mono suspension, so I checked mine and found no cracks. But I am worried this will eventually happen.
Any suggestions?![]()
Just a suggestion, why don't you buy a '08 or '09 new pivot arm and keep your old 1 as a spare, by the time you pay a welder and down time to do it it'll end up costing a few $$$
If your SRUNG & VALVED correctly you shouldn't have any problems w/stock pivot arm...unless your a very aggressive rider DITCHBAGING and jumping all the time and bottoming out HARD you should be ok...I have a budie that has 10.000kms on original pivot arm on a '05.
- 7K
