phazerboost
I HAVE A 151X2 5/16 CAMOPLAST CHALLENGER TRACK AND I WAS WONDERING IF ANYONE HAS TRIED TO PUT LARGER DRIVERS IN. I WOULD LIKE TO INSTALL 10 TOOTH EXTRO'S TO DECREASE GEAR REDUCTION AS WELL AS IMPROVE APROACH ANGLE. I DON'T CARE IF I HAVE TO TRIM RAILS OR MOVE SKID BACK.
Thrusted Vector
Nine tooth will fit,don't know about 10 though.
phazerboost
I FLIPPED MY SLED OVER AND MEASURED THE GAP BETWEEN THE TRACK AND HEAT EXCHANGER. IT LOOKS LIKE THERE IS AN INCH AND A HALF. I THINK 10 TOOTH DRIVERS ARE ABOUT AN INCH BIGGER THAN THE 8 TOOTH THAT COME WITH THE MOUNTAIN LITE. THE TRACK ALSO HAS 5/16 OF AND INCH MORE LUG WHICH DOES NOT LEAVE MUCH ROOM MAYBE A 1/4 INCH AT BEST. WILL BE PUTTING THE TRACK IN AFTER CHRISTMAS AND POST RESULTS.
teerex
but you also have to cut the rails....
by the way, I never understood the problem of turning caps lock OFF
Phazed-Coug
teerex said:...by the way, I never understood the problem of turning caps lock OFF
He's got a keyboard with all capital letters... it happens.. factory defect.
Send it back, they'll replace it.
phazerboost
WE GOT SOME COMEDIANS IN THE HOUSE!!
NEED SOME CHEESE WITH YOUR WINE?
teerex
If you press the Caps Lock key, your letters will not be as shouting anymore ... :exc:
