kuvasz
I'm going to change my 9 tooth driver to a 10 or maybe 11 tooth driver. I've tt a couple of cat guys and they said they've heard of guys running 11 tooth drivers but you need to keep your track really tight or the studs will hit. I usually run my track tight but I do trail ride quite a bit and go on long distance trips. I don't need studs taking out my heat exchangers.
I'm using 1.325 triggers and I find the really penetrate well with a 1" track.
I appreciate any feedback.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Not sure they make a 11 tooth 2.86 if they did they would be huge and track may not fit. 11 tooth 2.52 is a viable option.
kuvasz
sorry, I should have mentioned the 10 and 11 tooth are both 2.52 pitch because I'm going to run a 1" hacksaw track.Not sure they make a 11 tooth 2.86 if they did they would be huge and track may not fit. 11 tooth 2.52 is a viable option.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
I believe an 11 tooth drive would have to be non extrovert, be good for speed running for sure. 10 tooth 2.52 is almost the same size as 9 tooth 2.86 so you're good. Ask Ben at TD maybe, I think a bunch of guys in Quebec run 11 tooth drivers, they like crazy long radar runs over there.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
11 tooth 2.52 will fit . The only issue is they hang down so are suspectble to damage for trail riding.
kuvasz
lol, i did! he wants me to run 11 tooth but i had concerns about trail riding.I believe an 11 tooth drive would have to be non extrovert, be good for speed running for sure. 10 tooth 2.52 is almost the same size as 9 tooth 2.86 so you're good. Ask Ben at TD maybe, I think a bunch of guys in Quebec run 11 tooth drivers, they like crazy long radar runs over there.
i only run 1320'-1500' tops. i watched a guy lose his track because he ran too far, not my cup of tea.
kuvasz
thanks! that's what i'm concerned with. i run trails 80% vs radar runs and drag racing only 20%.11 tooth 2.52 will fit . The only issue is they hang down so are suspectble to damage for trail riding.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Also I assume you have a 137 suspension, so if you convert to 2.52 and 136 hacksaw and then bigger drivers and say oversized 4th wheel kit things get tight.
kuvasz
that's another question i was going to get around too. i know with a big wheel kit on my 136 apex it's tight.Also I assume you have a 137 suspension, so if you convert to 2.52 and 136 hacksaw and then bigger drivers and say oversized 4th wheel kit things get tight.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I went 136 hacksaw , 10 tooth, with 8.5 wheels and the wheels were very close to the transfer bar (Not the blocks) . Now that the track has stretched a bit it's ok. Not sure if I could of gone 11 tooth.
