I'm not sure that they will fit. If they do, you will gain more contact with the track (less apt to ratchet) and higher gearing (a plus for a boosted sled). Your speedo will be off (not that t was all that acurate anyway). As stated earlier, if they don't have clearance, you may have to move the skid back or trim the tips of the rails. Also check the front heat exchanger (should have clearance there).
