Need to figure out the cooling flow of the Apex motor the service manual only shows the parts of the colling system but no flow direction, is the flow coming from the motor outlet into the water pump? Or is it from the cooling radiator into the water pump then into the motor? Reason why I'm asking is I have an Apex motor in a Polaris RZR and the cooling flow that I have now isn't working properly and I have dual radiators on this RZR conversion but they seem to be in parallel when they should be in series...any help will be appreciated
