I should know this but cant find it. If shock is blown(No Click on Rebound adjuster and Oil all over shaft) will the electronic adjust still adjust using dash and warmer rocker?
I have one with both issues and dont want to replace adjuster on shock unless its needed. Sled is not here. Just shock. Also best source for the electronic adjuster?
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
Provided there is nothing wrong with the solenoid it should still show that the adjustment on the dash works. If the shock is blown it may not matter. I don't know enough about the shock to say if it can be rebuilt without removing the solenoid but removing the solenoid does ruin the plastic case. No way around that to my knowledge. Those solenoids are not very durable and the wires often break rendering the solenoid useless.
I have always gotten my solenoids replaced by Hygear when the shock was in for service. A member Bjowett I think it is used to sell them also but, I haven't seen a post from him in quite a while.
HABS 1
- Oct 22, 2015
- corunna,ontario
had mine rebilt at shoc tec in guelph ontario, he put a new solinoid on it for me due to torn wires,got shock back and still coulnt acess adjustments on dash, checked everything, traced wiring, all good, turned out to be my ecm! i replaced with a good used one and all is good
Thanks guys. I have replaced solenoids before but never on a blown shock. Customer said guage did nothing also. He will get new solenoid.
- 71K
