marq
- Apr 14, 2003
- Bridgman, MI
- 2006 Apex RTX
Guys,
Rode my Apex for about 150 or so miles with no issues on Friday night. It sat for a few hours and when I tried to start it up the motor cranked but wouldn't start. I had accidently left my GPS (hard wired to the battery) plugged in and running while it sat and my initial thought was that even though the motor turned over and the fuel pump was running that perhaps the battery had drained enough that it wasn't sending fuel. At this point the sled wasn't throwing any codes, it just wouldn't fire.
The next morning I went to pick the sled up and again tried starting it. Again it cranked over without any hint that it would start, but this time it showed Code #12. I did some searching and it seems like when you get this code a new stator is in order, but it could be as simple as a loose connection, faulty relay, or a drained battery. I haven't had a chance to dig in it and look for anything out of the ordinary, but I'm wondering if anyone else has had this issue and if they found something other than replacing the stator.. i.e., which spots I should be checking for rub throughs or loose connections.
Here are some specifics about my sled that may or may not be relevant:
06 Apex RTX 10,400 miles
New battery this year
SledStart HID's
Original bars with upgraded hand warmer harness (never above 3 bars)
Hardwired GPS. I'm running an inline fuse and an on/off toggle switch
I'm prepared to pick up a new stator assembly if I have to, but I don't want to find out it wasn't the problem after replacement. Me and volt meters aren't really friends.
Thanks,
SledStart HID's
Thanks,
