LAKECITYAPEX
What is the top speed of an Apex with 23/38 gearing? Is there a gearing chart that show you an approximate top speed with gearing? Which gearing is a better a 23 or 24? Thanks
fourload
I've run the 22,23 and 24. The 23 is probably the best all around gear. The 24 is slightly faster on perfect ice, but everywhere else the 23 is faster. The 22 is probably the best fast trail gear. Make sure you have good traction if you gear down or it will go up in spin!!! Leave the 24 in if you have no traction.
Terminator
fourload said:I've run the 22,23 and 24. The 23 is probably the best all around gear. The 24 is slightly faster on perfect ice, but everywhere else the 23 is faster. The 22 is probably the best fast trail gear. Make sure you have good traction if you gear down or it will go up in spin!!! Leave the 24 in if you have no traction.
X2 - 23 on my 2011 XTX flat out rips!
