I'm looking for advice choosing a NEW track for a friends Apex GT 136" ( 2008 )
( OE track: 136" x 15" x 1,25" ---> Now completely broken )
What is maximum lug height with stock drivers ?
What is the preferable pattern for off trail use but still 136" long ?
1. Camso , BRP pattern , 136" x 15" x 1,75"
2. Camso , BackCountry , 136" x 15" x 1,75"
3. Camso , Challenger , 136" x 15" x 2"
4. ???
4. ???
darv
- Aug 9, 2005
- 08 Apex 40th LTX
you can only go 1.5 is the hight you can go unless you take out the tunnel protectors . i have the same sled and put the cobra 1.354 in mime and it works great.
OK, so these sleds have tunnel protectors from factory ( I wasn't aware of that )You can only go 1.5" is the hight you can go unless you take out the tunnel protectors.
I have the same sled and put the cobra 1.354" in mine and it works great.
but since no one over here in Europe use studs in the track, that should not be a problem to run without them.
What about maximum lug height combined with stock drivers ?
darv
- Aug 9, 2005
- 08 Apex 40th LTX
you might get in there 1.75 but you will have to measure.
I ran a Ripsaw2 on my Attack then changed to an Ice Attack because of the prestudding...huge mistake for me.
The Ripsaw 2 on my Attak was the best trail/offtrail track I have ever had on a sled. The Ice Attak just doesn't cut it in loose snow and we rarely need the little studs in my area.
put a 1-1/2" talon in my 11 with no issues or mods.
