TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Is this specific to MCX or can you get from a supplier of the Mits 16T Turbos? Mine had a bunch of water in it and froze( I from assume snow dust) Also the dude that installed the kit had straightened the control arm cause it was pulling to much boost and now it rubs on the housing....the boost is all over the map it seems so hopefully this is the problem... What is the max boost can I get out of that waste gate actuator without a boost controller?
I know you can get them from MCX for 250 wondering if there cheaper anywhere...seems high for a small valve actuator..
