offside
Need some help with my Yamaha apex year 2007 with MCX 290hk kit. I live in North Sweden. I have updated a lot on my snowmobile and changed all bearings, TrackPoint, ne-abrasive and fixed all dampers and configu bogie for my weight. My setup.
Primary: Supertip 60g, inner hole 6g. middle 14g and tip 3g. Stock rollers 14.5 and yellow, silver, yellow primary spring.
Secundary: Dalton helix 54/48, Yamaha, white spring, 2-6 = 80 degras
Bombarider track 41mm, 345 cm long and 9 Tooth noslip
22 top gear, 38 lower and 68 chain
Top rate 10 900 rpm (1.1 bar). Engagement, I do not know.
Fuel: 98 octane and tripack octane booster.
My problem is that it wants to go in rev limither from full-throttle start. When I run on trails. When I'm off the trail, sometimes. Are gun happy besides. The spring in the primary is new and secondary are used. Picked it apart tonight and could see that it was the belt
residues at the bottom of the secondary. I'll buy a new spring in the secondary and it is leaning towards Yamaha white. I'm very close to being happy and thought in case anyone could help me.
Thanks in advance / Tobias[/img]
