Bodacious
Does anyone by chance know if the Apex Mnt rear springs are interchangable with my MTX springs? If so are the Apex Mnt a stiffer rate? Lastly if anyone has a set for sale please PM me! Thanks in advance!
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
The`fische`shows them to have thesanepart # for both sleds. They showthe same alternate spring too
Bodacious
Thanks!!!
MountainMax
- Nov 21, 2004
- Churchill Falls, Labrador
- 2009 Yamaha Apex
are the stock springs the heavier or softer then the alternate? it don't say which is stock in the parts catalog...
GotJuice
spring weights
stock springs are lighter, heavier ones are 2100's
>>MountainMax said:are the stock springs the heavier or softer then the alternate? it don't say which is stock in the parts catalog...
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
Good to know, Im a heavy rider (about 250) and I was told i may need stiffer springs...
Bodacious
Re: spring weights
Springs are actually available in:
1300kg stock
1500kg
1700kg
1900kg
2100kg
(all from Yamaha)
GotJuice said:>>MountainMax said:are the stock springs the heavier or softer then the alternate? it don't say which is stock in the parts catalog...
stock springs are lighter, heavier ones are 2100's![]()
1300kg stock
1500kg
1700kg
1900kg
2100kg
(all from Yamaha)
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
Where do you get the part numbers? and will these also fit the Nitro MTX ??
Firemann32
- Oct 27, 2007
- Springfield, MO
- www.swmosportbikes.com
I have a set of stock springs off an 07' APEX MTN if you need them.
This makes me curious to know what rate I got when I asked my dealer to order me a heavier set.......
Bodacious said:Springs are actually available in:
1300kg stock
1500kg
1700kg
1900kg
2100kg
(all from Yamaha)
