Ironmanstl
CROW said:I'm 215 w/o gear and I haven't bottomed out the light setting on the 2100's. I would think unless you're 250+ the 1700's would be okay depending on riding style. I think they make 1900's though.
Here's the p/n for the 1900's 8ES-47474-10-00 & 8ES-47473-10-00 $58 each
This sounds about perfect for me.
I have the stock MTX on the stiffest setting and its quite EZ to push the bumper down.
Going to order them tomorrow
thanx for the part numbers
Bodacious
Replacement Springs available for Yamaha:
1300kg (stock)
1500kg
1700kg
1900kg
2100kg
1300kg (stock)
1500kg
1700kg
1900kg
2100kg
CROW
Bodacious said:Replacement Springs available for Yamaha:
1300kg (stock)
1500kg
1700kg
1900kg
2100kg
Also 1600 and 2200
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
I replaced mine with the 1700 and I'm happy. I weigh 250+ in riding attire.
Bodacious
Just installed a set of 1500kg's I got from Ulmer. New out of box I'm able to set on the softest position. They hold the rear up where it should be. I was hoping that only going to the 1500Kg's the rear wouldn't pogo the shock and it doesn't. I'm sure it will take a few hundred miles to be convincienced that they were the right choice for me. ( 235 with riding gear)
2XM3
2100's, I am about 310 dressed with pack, 6'7" 275 in street clothes.
spray25
Deos anyone have the part number for the 1700 ones? Woodsrider I think you used them? What are they off of and were they a direct bolt in on the MTX?
Ironmanstl
I believe MTX and Nytro are the same spring through out
You can check through various years here till you find the part you want
http://www.ceyamaha.com/pages/parts/vie ... fault.aspx
devil
i put the stiffer apex springs on my mtx, very happy with them so far, no more bottoming out.
Firemann32
- Oct 27, 2007
- Springfield, MO
- www.swmosportbikes.com
If anyone is needing a stock set of APEX springs I've got a set. Hit me up with an offer.
Ironmanstl
Just finished putting in the 2100's, glad I finally chose those over the 1900's.
Feels just where I want it to be
230lbs+gear
230lbs+gear
woodsrider
- Feb 17, 2005
- Lewiston, ID
Spray - the 1700's are stock on the mtn apex the apex and the nytro are interchangeable sorry I don't remember the part number and I already threw the packing away just tell your dealer and he will know what to get
randman516
looking for the #for 1700 apex springs.
All I can find is,1300,1500,2100, thanks for the help.
Koeckman
Crow,
Do you have any contact info for where you purchased these springs for $58 bucks. I contacted my dealer and they want $120 each. Thanks for your help.
Koeckman
Just purchased the 1900's from South Seattle Sports Plaza. $69.13 each not bad seeing how my local dealer wanted $120 each.
I hope I don't regret not going with the 2100's as I go 6'1" 230 + gear. (sounded like the 2100's were pretty stiff and the 1900's had a little give)
Anything would be an improvement over the stock springs.
The price for the 2100's through them was $76.58 each.
