doo_man
Just getting ready to change out my drivers(RX-1 Mtn to 3 pitch Apex drivers), have rough idea on where everything goes. It looks like the two middle drivers remain in the same location, anyone have the Tech manual dimension diagram so I can get this right the first time? Just want to make sure on the proper set up for the extrovert drivers, I know I line up the arrows but what about the L and R side which is which and does it matter?
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Apex drivers
Put in Avid drivers cause stock ones are junk!
600 KMS and the inside of one sprocket was spun and outside of other one.
alaskanbowtie
do you think they did anything with the drivers for 07' or they still making excuse's for there workmanship.........
I'd like to thank you Powderlite's for saying it as it is instead of making some lame excuse about the heat from this or that..... blah blah blah. They are JUNK period . Thank you, someone straight forward and honest!
doo_man
Avids will replace these when they are worn. They are "brand" new and were part of the package!
talldude1
- May 10, 2006
- Vail, Colorado
- www.trackpunch.com
What about the 3" pitch wahl drivers? are they worth a darn or is there timing issues with them?
Turbo Tim
alaskanbowtie said:do you think they did anything with the drivers for 07' or they still making excuse's for there workmanship.........
I ran mine all season with 12- 17 pds of boost . No problems , but I keep my track pretty tight............I've got Avids on my TRx1 and they are the bomb! .......That's what the Apex will get when the time comes.
