munskindaddy
I had to adjust the linkage on my reverse last fall, now when getting my sled around it's grinding again. I just put new bearings in the drive and Jack last fall. What is causing the thing to basically go slack and not fully engage?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
did you lose the little spring in the chain case?
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
What thor452 said, and, double check your chain tension adjustment and ensure tension bolt is locked, they do back out.
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
On mine one bolt top of case comes loose every once in a while. Its one with a locknut on the back side, thinking I may have to change the locknut.
munskindaddy
I will have to check that. I think it's all good, but I'll checkOn mine one bolt top of case comes loose every once in a while. Its one with a locknut on the back side, thinking I may have to change the locknut.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Just to clarify its one that holds a reverse linkage arm, when the bolt it loose the arm twist enough that the sled does not go all the way into reverse and skips. The nut is hard to get at with a wrench.
Winderallday!
- Dec 4, 2007
- SW, Ontario
Below is the reverse linkage arm #31 Sasquatch is referring to I believe, it pivots on a collar bolted through the chain case housing. The nut is a nylock style, even so, sometimes they back off or get overlooked at re-assembly and make this whole linkage system slack causing incomplete reverse shift.
I have read it is also important that the gap between both sets of Hime joints are the same by adjusting #38, the gap should be 27mm if I recall correctly.
Cheers.
Cheers.
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Yep dat be the one!Below is the reverse linkage arm #31 Sasquatch is referring to I believe, it pivots on a collar bolted through the chain case housing. The nut is a nylock style, even so, sometimes they back off or get overlooked at re-assembly and make this whole linkage system slack causing incomplete reverse shift.
Cheers.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Check the wear on the fork, the ends wear down and make it go out of adjustment.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
I have come across that same thing in my group of riders, seen that on a couple apex's, first time I encountered it the one guy took his chain case apart twice trying to figure out what was wrong, he asked me to look at his sled and I checked his linkage and noticed that linkage pivot arm was twisting side ways ever so slightly when trying to shift the chaincase and I tightened the bolt that Sasquatch is refering to and problem fixed.On mine one bolt top of case comes loose every once in a while. Its one with a locknut on the back side, thinking I may have to change the locknut.
munskindaddy
Ok guys, you hit the nail on the head. Thanks for making that an easy fix!.
snowman 700
- Oct 10, 2005
- Mid-Michigan
- 2011 Apex SE
2012 Vector (wifes)
X2 I have to tighten this on my apex and the wifes vector. It doesn't have to be too loose to make it slip.Just to clarify its one that holds a reverse linkage arm, when the bolt it loose the arm twist enough that the sled does not go all the way into reverse and skips. The nut is hard to get at with a wrench.
