mr. shide
Picking up a 2011 apex se today. Any ideas about where i should set the psi in the fox floats? Im 180lbs. Moderate to aggressive trail rider. Also how much does air temp and baro pressure affect psi settings? Is it something you constantly have to adjust psi for? Thanks.
I did 55 up front and 155 in the rear on my buddy's SE. Started at 45 and 145 and seemed to bottom out on the bigger bumps. He is close to your weight.
mr. shide
Ok good deal. What about the limiter strap and the transfer rod settings? Factory?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
62 Front.
158 rear.
Limiter up one hole.
Transfer rod to 1 line less than Max.
Semi Aggresive Sno Trackers.
158 rear.
