Powder Pounder
I am looking at trading my D8 for an 07 apex, has the MPI stage one super charger on it, running 10-12 pounds. All super charger updates were done two weeks ago. Has head shim and after market head studs, GEMS fuel controller, boost gauge, under tunnel exhaust, Mountain Mod seat, not sure what else. Was Built by Darren at E&S in Fort Sask. I'm wondering if there are ANY problems with these after the updates? Anything to keep me from buying it? I would be running it at mainly 1000-3000'. (Pump gas with head shim?) And a few trips to the mountains a year. I know the GEMS can be a head ache, but how bad is it really? There was one guy around here with one, he blew an intake gasket I believe it was, he then sold it. I want a sled I can set up once, and after that get on and ride it. Are these reliable sleds with the super charger on it? I was looking to sell my D8 for a nytro, then add a MCX 180 kit. But got this offered to me for a killer trade deal. So it caught my interest. I have heard Darren builds solid sleds, and not to be scared of it if it's one he put together. I asked on Snowest, and got almost all positive responses, but since this is an all Yamaha site I thought I would check with you guys. Looking for the good, the bad and the ugly on these things.
Thanks.
Thanks.
heath@mpi
- Aug 20, 2008
If sled was put together properly you will not have any issues. Once you get the controller setup and are familier with using it you shouldnt need to mess with it if u ride similier elevations,
Critical is belt tension and pulley installation and make sure oil vent line for supercharger oil tank is routed properly and not in the nose of sled.
Give me a call if u need
Heath
Mountain Performance
888-649-4609
Heath
888-649-4609
Hi Heath,
What is the proper way to route the oil vent?
heath@mpi
- Aug 20, 2008
Just make sure it is not routed down into the nose of the sled.
it will suck up water when the ice melts.
Powder Pounder
Thanks for the help heath, the guy sent me text saying he sold it for cash instead of our trade deal. So this one is out I guess. O well.
TomKat
- Dec 2, 2006
- Idaho
- 2006 SCAPEX
- Pocatello, ID
heath@mpi said:If sled was put together properly you will not have any issues. Once you get the controller setup and are familier with using it you shouldnt need to mess with it if u ride similier elevations,
Heath
888-649-4609
Heath, could you please elaborate on the belt tension please. Thanks!
heath@mpi
- Aug 20, 2008
Just make sure the belt is tight. Very tight nothing extreme use your best judgement.
If you can push on the belt and it moves .5 inch its to loose
TomKat
- Dec 2, 2006
- Idaho
- 2006 SCAPEX
- Pocatello, ID
Thanks Heath!!
heath@mpi said:Just make sure it is not routed down into the nose of the sled.
Ok, mine is going into a catch-bottle first, then the overflow from the bottle is NOT loose at the bottom of the nose.
Thank you for the info.
A
