axman977
- Jan 26, 2014
Hey everyone,
Weirdest thing happened to me today. I had brought my 07 Apex GT in to re-secure one of the extra tunnel protectors that came loose. Pretty routine stuff for me, I dropped the skid, did my work and put it back together. When I went to start the sled and load it back up, it started fine so I turned around to open the garage door and the sled cut out. I went back to re-start and it cranked for a second then nothing. Dash was still on, it threw a code 81 for a second (Grip warmers I believe) and then the highbeam indicator light came on. I'm at a loss. There are no other codes that I am aware of but I've had a few problems this year already. I recently installed the yamcharger with a PCV and Ignition module. The ignition module was giving me all kinds of trouble throwing codes 33-36 so I unplugged that and have been running with just the PCV. I contacted Dynojet to trouble shoot the Ignition module, but I don't own a laptop to work on it. Going to try and borrow a friends. Until then, any ideas on why the sled suddenly doesn't want to crank and why the highbeam indicator is coming on?
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Try checking your ground blocks.
axman977
- Jan 26, 2014
Any specific location (s)?
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
This will show you where they are
http://www.ty4stroke.com/threads/apex-wont-crank-and-no-fuel-pump.83994/
sxray
- Mar 2, 2006
- grand blanc, mi
- apex
Also check starter relay, have had two in our group go bad this year.
