granto211
Started the sled this morn ran fine drove 500ft to get gas shut it offf filled up started fine and ounce i hit the gas it bogged and died. I put in 91 octaun on 1/2 tank so i dont think its the fuel. It just cranks n cranks, with no codes. I here the pump when i turn the key and i can smell gas when i try to pull the throttle while starting. Please help
Did you let the engine warm up before you drove 500 feet? Could be fouled plugs? Also, you could check the connection from the ign switch to the harness. I helped out a Nytro on the side of the trail. He stopped to change gloves or something and then he went to start the sled and it would not start. Wiggled some wires around with the key in the start position until we got some life out of it. Turned out to be a bad connection off of the ign switch.
granto211
Yes it warmed up for about 10 min, is the bog n die pretty tipical of fouled plug. Its got 5k miles now
granto211
I knew yesterday was too good of a ride, she is on the trailor headn the 4hr drive back home.
Hopn its just the plugs but there will b no snow when we get home so thats my summer long memory of my apex
granto211
Weird just got a call from A lady whos sled burnt up after filling up at the same gas station where we filled up in silver bay saying there was 4 sled that quit running after filling up and it turns out the gas was bad. They want to remburse me and pay to have it repaird if needed. Do u think this caused plugs to foul or do i just need to drain the gas and its good to go? To bad we are about 30 min from home now.??
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
sled
drain the gas, put some seafoam in when you fill up with good gas,
Is it that 06 RXT in you avatar? if so I had one and my buddy had one both broke a wire above the right side foot hole. Niether had any warning. The dealer took my buddies in on trade not running and took about 5 hrs for them to figure it out. Same type of deal shut it off and went to restart and no fire.
grader
drain all the gas from the tank and if there is a bleeder on the fuel rail pump new fuel through it as well.
granto211
Just draind the gas put some new premium in with some heat and it fired right up. Wish i woulda thunk it when i was in silverbay, coulda rode
Shiek
- Jul 21, 2004
- www.sledbitch.com
- 06 apex gt
gas
you need to have a phone with internet!!
