I put a new ripsaw (warranty from Yamaha) on my 03 with 120 woodys down the middle. The first time out I noticed bad ratcheting just like last years POS finger. Went in to tighten track and noticed the heat shield was ripped off by the studs. Next day rode 60 miles in the ditches no problems. Are these things Needed??? If they are, is this something Yamaha would warranty??
RX1 Yooper
I rode all last winter, and my shield was perfect. I studded for this year, and the shield is bent up, after 1 ride. I have a 1.25 track. The studs stabbed a piece of wood, and did the damaged. I had to put it in reverse to get the wood out.
POWERHAULIC
My heat shield departed the sled about 600mi. ago. There have been asolutly no ill effects without it, just as i suspected. Also the studs have never touched the pipes.
Focker
Mine is loose and I thought about taking it off, but kinda second guessed myself. If you think about it, that little piece of metal isn't going to protect anything from those studs if it came down to it, so I think I will just take mine off instead of listening to it rattle.
POWERHAULIC
Yes, removal is necessary the rattle is unbecoming to an RX1 :!: 8)
Buckeye
- Lakes Region, NH
Rattle
You think that rattles, you should hear my gear reduction rattle at idle. Sounds like a bucket of bolts. Still works though after 1800 miles. I have 1.25" studs and my heat shield still looks pretty good. I was surprised.
LazyBastard
I have no studs and my heat shield is still bashed up. Not torn or loose at all, just bashed up.
LOL. I think I'll just leave it.
snowman
Mine has cracked at both ends so i added 2 more rivits and that held it,but 2 days ago i installed the GP-1 and left it off completly,
my dealers mechanic said i don't really need it,maybay someone may find use for it at the dump :lol:
- 47K
